Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Screen Replacement Home button keeps touching itself.
I just replaceed a screen for a customer, Ipad mini 2 screen. Now after the screen replacement the home button keeps double tapping itself and is opening the recent apps. The ipad can not be turned of because when you try to press the power button it keeps taking a screenshot because the home button is pushing itself. Can anyone please try to help me out with this issue I am having. I checked the home button adn there is no damage at all to it and I tried to reset the flex cables to fix that issue and that is not working.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi,
Home button may be too tight, try putting a thicker bit of adhesive under the bracket, this will create a bigger space between the home button and bracket, and may resolve your issue. :-)
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
cellphonebuyer1 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 74
