It doesnt turn on, or do anything after fall...
i had My girlfriends iphone on my pocket and i fall having it in my pocket...the iphone seemed like nothing happened, no scratches, no broken screen, no nothing...but i didnt turned on nor wanted to receive any charge. Currently is with some technicians but the dont find what it has. They told me that everything inside seemed perfectly normal, that they tested the screen and the touch and it worked, and they also tested with a new power supply and it didnt turned on neither. the iphone is supposed to be in warranty but where she lives is a little warm place, the dock sensor was a little pink. So I was wandering what could be the problem or if i can change the sensor? ( because all sensors even the ones inside and the headphones sensors where white). I Hope that you guys can help me...my girlfriend really needs her iphone cuz she used it as a modem.
Это хороший вопрос?
2 Комментариев
My iphone 3gs has done the exact same thing, will not power on, light up or anything after being dropped from about 2 feet. I had it in a otter case. There must be a common problem for these phones to do this with no apparent physical damage.
I someone has had a similar problem, please post.
I think I am going to buy a different brand next time!!!
Later, Dave
из David Carroll
Is it recognized in itunes when plugged into the computer?
When you switch the vibrate switch back and forth, does it vibrate?
из repairthat
