Второе поколение iPhone. Модель A1241; 8 или 16 ГБ памяти; с черной или белой задней пластиковой крышкой. Ремонт проще, чем первого iPhone. Требует отвертки и инструментов для вскрытия.
iPhone does not recognize any Sim
Hello,
My iPhone does not recognize any Sim.
What part do I need to replace / fix?
Thanks (
Это хороший вопрос?
Счет -1
Добавить комментарий
3 Ответов
Выбранное решение
if this is a phone that is new to you- I would check the imei to make sure it is not listed as lost/stolen
clean the sim card
check sim tray for bent/dirty pins.
the paper under sim tray is a great idea..
Был ли этот ответ полезен?
Счет 2
Well... Try to put a paper or something thin (~1mm) between the tray and the SIM then put it on the phone.
I can't guarantee you that this will work but why not trying?
Счет 1
Please check if your iPhone have carrier lock or not ? If it is locked with any carrier, that sim only works in your iPhone . If you want to use it with other networks, you need to unlock it from the locked network . For that, you can get unlocking servcie from your service provider or from any of the online vendors like Prounlocking.com to unlock it . Once, you have removed network restriction from your iPhone, you can use it with any other GSM carriers internationally .After that, it won't accept/not recognize any sim card, it may be hardware problem .
Счет 0
Добавьте свой ответ
or erel буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 2,621
