The Stylo 2 (model number LS775), the second iteration of the Stylo series, is manufactured by LG and was originally released in April 2016.
Why is my power button heating up?
This just started yesterday. i need help because I'm afraid my power button will cause damage because of the heat. it cools down when i shut it down and i don't know what to do! i need help!
Это хороший вопрос?
Счет 0
2 Комментариев
I have the same problem with my mobile Xiaomi REDMI Note 10
из
Thiis is what is happening to me right now and we both use the same phone. What did you do to fix it?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@pizzapie9904 you'll most likely end up having to take it apart. Heat=short circuit. Could be your power switch flex or even a short on the board or the battery. Use this video for the teardown. then take a couple of your own pictures and post those with your question. For that use this guide Adding images to an existing question
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
thank you, I will look into a phone repair. I appreciate your help so much!
из
Добавьте свой ответ
Pizzapie9904 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 10
За последние 30 дней: 35
За всё время: 4,557
