Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
VRAM Modules Pads or Paste
Going to upgrade the Kaby Lake CPU to a i7, upon reassemble should I use thermal pads or thermal paste on the VRAM Modules of the GPU, if pads what thickness should I use 0.5/1.0/1.5 or 2.0, like the ones used by EKWB on there GPU waterblocks, if paste should I go with K5-Pro, or the same thermal paste I use on the CPU Thermal Grizzly Kryonaut/Arctic Cooling MX-4.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
Normal thermal paste will work just fine.
Был ли этот ответ полезен?
Счет 1
4 Комментариев:
If using thermal pads, what thickness should I use?
из
Has anyone measured, please? I have to order right thickness and delivery is like 10 days.
из
iMac 27” 2017 has a gap between VRAMs and cooler plate around 0.75mm.
из
Hi,
so a squeezed 1mm thermal pad should be fine, right? Do you think I need to use a little more thermal paste on the GPU die, in order to have the contact with the heatsink? Thanks.
из
Добавьте свой ответ
John буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 27
За всё время: 1,095
