Дата выхода 25 сентября 2015 г. Модель A1687 / A1634. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
1041вопросов Показать все
iPhone Water Damage Repair Help
The iPhone 6s Plus I have has water damage and won't turn on at all.
When charging it, the motherboard does not get hot at all almost like it's not receiving a charge.
It does not respond to iTunes or is recognized at all.
I took all shields off and used 99.9% IPA already.
I have realigned the power management chip of the bottom right side of the back of the board. (It was crooked).
However, a small little chip or capacitor has fallen off in the process (see pictures). How can I reattach this chip? Also which other chips could be responsible for the death of my iPhone with no heat at all?
Thank you for helping out!
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Well shooting for the Tristar is usually a good go to. Have you tested vcc_main?
Был ли этот ответ полезен?
Оценка 3
3 Комментариев:
I am fairly new to microsoldering so I'm not sure what vcc_main is. Could you clarify?
Also, the small little chip in the first picture is not important?
из
Nevermind, I have found vcc_main and the tristar chip. Will check them out. Thanks.
My only question that remains is what is the purpose of the small chip I knocked off in the first picture?
из
Blurry picture but it looks like a coil not a chip. Re tin the pads and replace it
из
@smarticles, it is FLDIP_RF, it is a signal filter and yes, important to have micro soldered back on.
Оценка 3
Добавьте свой ответ
Diego A будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 160
