phone stuck on service logo screen
i have a zte grand x max 2 and it now stuck on the cricket logo screen and will not boot any further. is there a way to fix it or is my last option to do a factory reset?
Это хороший вопрос?
Оценка 2
3 Комментариев
Before doing a factory reset try wiping the cache partition
из
Having the same problem right now. What did you end up with?
из
My ZTE Blade a7p won't work it's turning off and on won't respond to force restart or hard restart
из
Добавить комментарий
4 Ответов
Выбранное решение
Well, and I apologize I don't know exactly how it works. You can try OD1N, which you'll need the correct files to soft boot the device. If that doesn't take you'll likely need to do a restore
Был ли этот ответ полезен?
Оценка 4
Wait for the battery to die and than try again. If this doesnt work i think u have to do a factory reset
Оценка 1
I tried letting it die and tried turning it back on and it is still frozen on the logo.
Оценка 1
1 Комментарий:
my ZTE A320 blade stuck on the logo
из
I did everything that I could, dealing with all the options. I wiped the cache files, selected the factory reset option and it had no effect. In other words, nothing changed. I have a ZTE Blade (Z982) phone and my screen is still stuck on the ZTE logo. What do I do about this situation? Is there some kind of special trick that I can perform to make my phone boot up normally again?
Оценка 1
Добавьте свой ответ
gary будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 6,413
