Repair guides and support for smaller headsets that rest on top of the ear, also known as supra-aural headphones.
I have IFrogz headphones
Brought them in Hawaii months ago , worked great , but all of a sudden they won't charge , and the charger hole keeps getting pushed into the headphones , so to charge I used to pull the ear muffs off to get better access , don't know if there just cheap or I'm doing something wrong ??
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
@eth110697 I do not think you are doing anything wrong. It sounds more like the charging port is most likely loose and moves higher up. To check on that you will most likely have to disassemble those. Let us know what exact model this is.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Ethan schloeffel будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 211
