Dent fixing, maybe gTool iCorner?
Anyone used gTool iCorner before band had any luck repairing dents from case of macbooks?
I know it says its for iphones and ipads but thought id ask
Update (09/11/2017)
Can you direct me to alternative tools??
Below is images of the damage. Customer dropped the laptop so the back cover doesnt close properly now
Это хороший вопрос?
Оценка 0
1 Комментарий
ouchy going to have to think on this one a bit ;-)
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Those tools may be nice but are high dollar. There are other alternatives I use but, if you would please post a couple of photos so we're on the same page as to what type of damage it is.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Did you have alternatives to recommend? My girlfriends laptop is now in the same condition as the above photo since a drop and I'm looking to fix it. Other than the back end of a spanner and a hammer, do you have any tools designed for the purpose in mind?
из
We shaped a piece of hard wood (ebony) to match the interior curve. We pull it all apart, use the block and a couple of jewelers hammers to help straighten it out. It will never look undamaged but with a lot of time and careful hammering, you can it back to a working condition.
из
Добавьте свой ответ
nick будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 186
