Bose's consumer range of active noise-cancelling headphones are called "QuietComfort".
Noise Cancelling Shorting Out
When I slide the control to Noise Cancelling, headphone keeps shorting out and goes in and out between total noise cancel and regular sound. Any suggestions?
Это хороший вопрос?
Счет 6
1 Комментарий
My power switch seems to not work. Van replacements be found?
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
I found out that - as crazy as it may sound - in my case it had something to do with the battery brand I used.
I normally use Duracells, but always found them a bit hard to insert into the slot (it was really hard to close the lid with the battery inserted), but never had any issues until recently I bought a new pack.
Just for the sake of it I used a battery from a different brand - Varta in that case - and not only do these fit better: Noise cancellation works fine again! No more interruptions, problem solved!
Best regards, Ralph
Был ли этот ответ полезен?
Счет 1
Hi Erica, have you tried replacing the batteries and or connecting to another device?
Bose QuietComfort 25 Battery Replacement
Счет 0
I have a similar problem, but for me the problem is actually the button itself, just touching it triggers static and it keeps dropping the right channel regularly.
Счет 0
2 Комментариев:
I have this problem too. I fixed it placing a small paper between the button (in "off position") and the headphone panel. It pushes the button a few mm inside the headphone and it appears to solve the problem. I think its a contact failure
из
what do you mean by between the button and the headphone panel?
A few close-up photos of this would really help!
из
Добавьте свой ответ
Erica Rubenstein буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 39
За всё время: 4,527
