Gaming laptop with a 13 inch screen released in October 2014. Can be identified by model number P56G001.
4вопросов Показать все
Battery not detected after replacement
My alienware 13r2 battery died, so I replaced it with one from BattPit (you can find them on amazaon). Now when I turn on my laptop there's an error message: the battery cannot be identified ... etc... wont charge.
My question is: does my laptop need a genuine Dell battery? Or can I somehow get this one from BattPit to work?
Это хороший вопрос?
Оценка 0
1 Комментарий
I also have alienware 13, bought a new Battpit battery, updated Bios, tried different chargers, replaced power port!!! Help!!!
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@zdan could be your charger, your BIOS or a bad battery. Since we can rule out your battery I would suggest you check the BIOS. Check this video at 04:20. Or you can just get an original Dell battery...;)
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Zachary Dan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 827
