Can I fix a hole in my radiator, or do I need a new one?
I think the answer to this one is going to be "no,' but if you don'task, the answer is always "no!"
After weeks of procrastination, hours of stripped-bolt frustration, and a brief period of euphoria when I successfully replaced my thermostat, I attempted to reattach the hose to the top right of my radiator, as one does. In shoving it on there, I managed to rip off the hose connector and surrounding radiator completely. There is a hole about 2.5 inches radius where my radiator would attach to the hose.
Can I glue the stuffing outta this until I have the money to replace the radiator? Can I just replace the top plastic part where the hose should attach?
I need it to drive 30 minutes each way from work, about 15 miles at the outside.
Update (10/02/2017)
These are pictures of the problem.
Это хороший вопрос?
2 Комментариев
Thanks for the response, Blake. I was going to try some 500* epoxy on it, but I wouldn't want to cause further damage than is already done, so I think I will wait until I can get the new one. At least a new radiator isn't as bad as replacing my head gasket could have been!
из Cassy BoBassy
I tried something similar on my A4 Audi, and it just blew out at work and I needed a tow home and a new pipe. My advice if in doubt don't!
из sm_vulkus
