Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782вопросов Показать все
MacBook Pro 2011 completely dead and unresponsive yet charging
Hi,
I bought this 2011 MacBook Pro 13" i7 (8GB RAM, 256 GB SSD) this year. It's been performing like a beast.
My charger broke about three weeks ago due to wear and tear, I ordered one last week which also broke after a few days.
I thought this was strange but ordered yet another one which arrived today, it's charging the battery but nothing happens when I press the power button, no noise which I usually hear upon start up, nothing.
I've tried the SMC reset but not working. Also note - it had a small 1 FT drop whilst laying dead for the last week, small drop but seemed it landed heavy enough.
Any options on what I should try?
Thank you in advance.
Это хороший вопрос?
Оценка 0
1 Комментарий
Where did you get the charger? There are quite a few clones floating around again which can damage your system!
- Counterfeit Macbook charger teardown- convincing outside but dangerous inside
- Lacking safety features, cheap MacBook chargers create big sparks
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Sadly, it sounds like your system is in trouble here. First review this Apple T/N: Apple Portables: Troubleshooting MagSafe adapters. See if it offers a clue on whats damaged here.
Был ли этот ответ полезен?
Оценка 1
The drop has nothing to do with it. You need to try a genuine apple 85W magsafe before anything. The copy chargers tend to kill the ISL chip on your motherboard.
I get sent tons of machines with no power issues. I plug them into my charger and they work flawlessly.
If your machine does not work with a different charger, you have a board level issue and someone skilled in microsoldering and board repair should be able to help you.
Оценка 1
Добавьте свой ответ
Cathaoir O'Doherty будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 502
