Temp gauge sometimes reads full scale
Mitsubishi Cedia 2002
Temp gauge intermittently runs to full scale but water not boiling?
Have heard there are 2 sensors on this model Can only find one at this stage
Это хороший вопрос?
Это хороший вопрос?
Hi,
If the sensor you found has only 1 wire connected chances are that it is the temp gauge sensor. You could prove this by disconnecting the wire from the sensor and then connecting it to earth. Switch the ignition to ON and see if the temp gauge registers full scale.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 119
2 Комментариев
@hamster1 Mitsubishi Cedia 2002 as in the Japanese version of the Lancer? What engine size does it have etc.?
из oldturkey03
I believe it is 2L
из Jim Dillon
