The Samsung Galaxy J1, released January 2015, model number SM-J100VPP/SM-J100H.
The backlight is not working.
My phone just turned off and then when I turned it on it doesn't lit anymore
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
@ameliadepp could be the backlight in your display or the backlight driver as well. I would start with a new display assembly. Use this guide Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement for that, If nothing else it will be your known-good point for further troubleshooting. Use these as your guide for further troubleshooting if it should be necessary
Был ли этот ответ полезен?
Счет 0
Vertical irradiation the screen with a strong light, if you can see the pictrue, the back light is bad and you need to repalce a new LCD screen. If you cann't anything, the display may broken.
Счет 0
Добавьте свой ответ
Mary Joy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 10
За всё время: 3,072
