Первая модель iPhone. Модель А1203; с 4, 8 или 16 ГБ памяти; и алюминиевой задней крышкой. При ремонте придется помолиться и немного попаять.
224вопросов Показать все
My iPhone 1st generation does not charge
Hi, I recently bought an iPhone 1st gen from eBay. It worked fine for a few months but now when I plug it in it says charging please wait, and after a bit it boots up. After arriving at the home screen, it says low battery and does not charge any further, and it loops in that way continuously.
Thanks.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
more than likely either needs a new battery or charge port as its an old phone
Был ли этот ответ полезен?
Оценка 1
It looks like this may be a similar issue? My iPhone 2g is not turning on or charging
Try a hard reset "holding home and power buttons whilst plugged into a power outlet" then try cleaning contacts. If that doesn't work you may need to replace the battery.
This answer also suggests simply trying another charging cord wont turn on or charge
Оценка 1
Добавьте свой ответ
Luca будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 799
