Water damaged problem can soak with alcohol or not?
just wonder my phone is damaged due drop in a pool,if i wanna use alcohol to clean the motherboard,how long its take to soak in alcohol?
Это хороший вопрос?
Это хороший вопрос?
You should also replace the battery if it has swollen. Resist the temptation to pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
Был ли этот ответ полезен?
I have watched a few videos and about to try to see if I can resurrect an iPhone 6 that was dropped in water nearly 3 years ago…the phones in mint condition lol other than the fact it doesn't work
I shall report back with the results…Kris SK
I don't recommend you to use alcohol I would recommend you to use rice.
Rice actually promotes evaporation and does not get rid of the deposits nor does it stop the corrosion..rice is great if your going to claim insurance but if your doing a real repair to a 500 dollar plus phone and you don’t have either; the suggested guide is proper to follow.
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 8,100
