iPhone 7 which is dead
i have an iphone 7 which is dead i tried everything i could but nothing, i measured every single caps on the board but no short and ,also i did connect it to a power supply zero amps , but when tries to boot up it goes up to 0.06 or 0.07 ma and stays there
i was wondering if someone can help ,also i measured voltages from PMIC
all the rails have the right voltages :{
and i tried to make it hot with power supply but as the currents consuming is very low it doesn't produce enough heat
thanks for reading :)
Это хороший вопрос?
did you check tristar
из daniel
Or batt_main?
из iMedic
Yes i did replaced the tristar and batt_main is work well as i get normall voltages from pmic
из yousef
is it taking amps on the power supply without the power button being pressed
из daniel
hi ,no it does't
из yousef
Показать ещё 4 комментариев
