The LN-T5265F model is a 52" HD television from Samsung.
35вопросов Показать все
Tv won’t stay on
Tv turns on but turns back off
Это хороший вопрос?
Оценка 0
1 Комментарий
bbeaup828 does this happen immediately? What have you checked? Can you turn it back on as soon as it turns off or do you have to wait to turn it on? Remove the back and take a good look at all the boards. Check for any damage. Post some images of your boards with your question so that we can see what you see. Use this guide Adding images to an existing question for that
из
Добавить комментарий
2 Ответов
Выбранное решение
Take the back off and see if you can spot any domed or leaking electrolytic capacitors - probably the commonest problem (See https://therestartproject.org/wiki/Basic...).
If they all look fine check for anything else that looks overheated or burned.
Был ли этот ответ полезен?
Оценка 1
There's a class action law suit on this. I lost mine too.
Оценка 1
Добавьте свой ответ
bbeaup828 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 865
