Выпущенный 16 сентября 2016 года смартфон нарекли iPhone 7 Plus. Вышло несколько моделей нового устройства: A1661, A1784, и A1785, а также можно было выбрать между версиями на 32, 128 и 256 Гб встроенного накопителя. На выбор можно было приобрести золотой, розовое золото, серебристый, Jet Black и (PRODUCT) Red оттенки корпусов.
3d touch and touch id not working..
The touchscreen i.e. 2d touch of my phone works fine but the 3d touch isn’t responding...?
I tried reseting the phone but it just avoids to work..
Even the Touch ID is not working even though the home button works just fine but the finger print isn’t sensed......
I had a screen replacement once.
I would be nice if you help me in finding the problem with it...
Это хороший вопрос?
Счет 1
Добавить комментарий
4 Ответов
Выбранное решение
Hi,
Both the 3D Touch and home button run through the same cable, I would highly suggest trying another screen, as there may be damage in the cable. :-)
Был ли этот ответ полезен?
Счет 3
3 Комментариев:
Are you sure as I have problem only with my Touch ID but the home button still works.
из
Yes, I am quite positive, try another screen and let me know, also make sure it’s not a poor copy screen
из
Sure will do that..!
из
I had the same problem, and after i replaced it with the old screen it all worked and I found out that some how the little cable was broken:(
Счет 1
1 Комментарий:
I e replaced 2 screens and still can’t get working properly
из
I have 3Dtouch, touchID and force touch not working after I opened My iphone7plus, maybe changing screen I can solve the problem ?
Счет 0
1 Комментарий:
I’m pretty sure you have damage one of the flex cable ( the lower one) it’s very easy to . i have done it a few times:( So you you have to be very very very carefull when you open up your phone.
из
I have this problem too with my iPhone 8 Plus, the flex cable doesn’t even seem damaged at all.
Счет 0
3 Комментариев:
It is for sure damaged, change backlight and all will be right
из
When I opened my 7 plus I couldn’t see broken flex till I put away backlight screen protection. If you opened your iPhone and from that moment Touch ID and home button doesn’t worked anymore, is for sure the damaged flex. Don’t change any other things, don’t’ change home button, just be very very very careful and change back light. By change only back light your screen will be good as usual. if you change all the screen with a preassebled as GIGA FIXXO ON AMAZON, it will be very easy and secure, but you will not have the original qualiti of apple screen
из
Attention, flex Brocken is not the one you see near the home button!! The flex Brocken is under the protection of the screen. Don’t do it by yourself become is too risky, go to a Chinese or to a Irepair, and say that you want change backlight (15€ Part cost)
из
Добавьте свой ответ
Shivam Patil буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 18
За всё время: 3,364
