phone is stuck in headphone mode
phone is stuck in headphone mode, plays ringtones but will not play media. im replacing a screen also, should i replace the headphone assembly also?
Это хороший вопрос?
Это хороший вопрос?
yes. this is the most common reason for your issue.
The HSJack, and CP shorts are usually the reason that it gets locked into a media center mode. replacing one of these two fixes the issue you have the majority of the time
Был ли этот ответ полезен?
where are the The HSJack, and CP shorts located on mb?
sorry, short is a term used to describe two electrical nodes, touching when they arent supposed to be. the actual components themselves, (Head Set Jack, and Charge Port) are what usually need to be replaced. you should be able to locate them easily, as they are the ports you plug in to.
I apologize for using the terms i throw around with the technicians in my store.
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 1,183
