windows 10 accountname delted , still name in net user
Hi all,
A question :
i have a desktop pc and i need to activate the Remote desktop like i did on several other computers.
Only this one is difficult with the user name ( accountname..)
lets say the original account name was kevin i changed it in kevcomp1 .
It recognized the new accountname.. the only issue was when i started RDP and filled in the username and pasword it did'nt work.. when i tried the old name it worked.
I opend a session in shel ( or cmd it will be the same..)
and i tried to delete en add a new user ( same name ) ( tried to remove the old username..) i did this with the net user command.
i added a new useraccount, deleted the old one
restarted the pc
when i checked the net user command i still see the old name ....
with the other pc's this is not an issue in RDP .. only on this one ... did i do something wrong? already tried to renew al the steps i did in RDP ...
is the only option to make a total new account and add it to the administrator ( with localgroup command in net command) but i need to delete the first and original one to make RDP work
probabely i did something stupid but stil...
thanks for the help y' all :)
Это хороший вопрос?
Оценка 0
1 Комментарий
Thx .. indeed this was it i was looking for
thanks again
из
Добавить комментарий
1 ответ
Выбранное решение
The "user's name" and the "username" are 2 different things.
Right click "My PC/My Computer" and select "Manage"
Find "User/Groups".
You will see there the true "username" where you can add/change/remove your accounts.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Kevin D будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 47
