Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
iPhone 7 LCD quality
Does this LCD produce exactly the same quality and color as the original ones? I did an replacement recently via 3rd party repair shop but being conned the display is grayish and not producing the color correctly.
Это хороший вопрос?
Счет 2
1 Комментарий
Hi Benny,
I bought the whole display assembly replacement from iFixit. Most of it was working fine, but the colors were a bit washed out. Then I noticed two things: autobrightness didn't work and when the phone got hot while charging some horizontal stripes would appear on the screen.
I contacted iFixit about the issue and they sent me a replacement. The replacement had the same issues, so I contacted them again. They offered me either a third replacement or a refund, and I told them that I would gladly take the third replacement if they could test that these issues I was reporting were gone. They decided not to test anything and only offered me the refund.
I think the quality is not nearly as good as with an apple display. Now apple offers a repair for $149, which is the same price the whole display assembly has in iFixit, so this is a no brainer. It's even cheaper, because in iFixit you'll need to buy the adhesive separately.
If you need a screen repair, in this case I would go to apple.
из
Добавить комментарий
1 ответ
Выбранное решение
Typically, you get what you pay for in terms of Iphone replacement LCD's. You could have purchased an inexpensive replacement part or have a defective LCD. Open the phone and look for the Apple Logo on the LCD Flex cable is one way to tell. If you spend $30 - $50 on an iphone 7 LCD, you bought a third party knock off and quality will not be the same as a $100 + Apple original LCD.
You can also ask the seller where he gets his parts and the quality. There is a bit of confusion on Original Apple LCD's, OEM, Class A and inferior knock offs. Different people have their ways of describing it and can be misleading.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Where to purchase oem lcds?
из
Most OEM products are refurbished by the broken original LCD screen
из
Добавьте свой ответ
Benny Chen буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 1,142
