Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299вопросов Показать все
Help! 98 Chevy 3500 stuck in 5th
My 98 Chevy 3500 C/T is stuck in 5th. There was no warning signs, noises... I got in my truck, started it and it wouldn't move out of 5th. I checked the hydraulic fluid and it looked like mud. Where should I start looking?
Это хороший вопрос?
Оценка 1
2 Комментариев
Is the vehicle stuck in 5th with no movement? If so I would check the clutch master cylinder and slave cylinder first. Try turning the vehicle off and see if you can run through the gears. If the clutch is not disengaging the transmission you will not be able to shift without having the proper meshing of gears.
из
Is the truck parked on an incline? Is the fluid your checking the gearbox oil or the clutch mater cylinder . Is there movement in the clutch ?and is the linkage able to move freely or is it possible that theres mud or debris in the linkage?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
I would start by checking your clutch master cylinder and slave cylinder to make sure that they are actuating properly.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Jessie Hill будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 190
