Samsung Galaxy S7 (SM-G930, SM-G935) — смартфон седьмого поколения линейки Galaxy S, анонсированный компанией Samsung Electronics 21 февраля 2016 года на MWC в Барселоне[
369вопросов Показать все
Why does my screen has a green vertical line on left side
Hello everyone!
As you know G S7 edge is water proof , so yesterday my screen was really dirty so I had to wash (done alot no probs) and then when I wanted to dry it there wasn't anything except air blowing dryer for hands (shopping mall) so I did after 2 minutes I saw a green line on the left side of my screen, my question will be, is it fixable? I don't wanna change the whole screen , too expensive , just to see if there is a way to fix it ?
Thank you in advance for your help
Это хороший вопрос?
Оценка 3
2 Комментариев
Water resistant not water proof big difference!
из
Can I ask a question able to fix my Huawei p8 green lines on my phone please fix mobile
из
Добавить комментарий
4 Ответов
Выбранное решение
My guess is the liquid got behind the screen which is where the LCD ribbon cable flex is.
If you are lucky you may be able to get away with just cleaning the corrosion behind the LCD if not the screen would need to be replaced completely.
While a phone is waterproof, it should never be intentionally in contact with water, because it'll always come back to bite you sooner or later.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Your Guess Makes sense, i will try to do that, see if it helps
из
Наиболее полезный ответ
Ok you could try this: go to dial and type *#0*# then click Red Green and Blue. Try it a couple times, it should reset the pixels. Maybe that is your problem, not the water.
Оценка 4
5 Комментариев:
@xacobecm Thank you , i tried it, but i think it is not the case because the green line gets on top of the green color too, i tried it many times, still the same, if only a part of screen is lit , the green line shows, so i turned off Always on display because the green line would show up if it is on.
из
This FIXED my problem! I had a vertical line up and down the right side of my screen and this fixed it... however... a few days later it came back. I did this again and it fixed it again..... hopefully it will not come back in a few days?
из
My s6 edge has not got wet, damp or anything else. All of a sudden I have this green line down l/h side of screen. Dialling *#0*# has made no difference. It has appeared after receiving news bulletin from Samsung. Green line pls go away before I take a hammer to this malfunctioning phone!
из
Thanks for that tip. I've tried it but I'm unsure by what you mean when you say 'click red, green and blue. When I key that in, my contacts come up (after hitting' enter').
из
So I did It and it came back
из
I have two lines 1 green on the left side and one red on the right side. On the right side if I put pressure all the way on the top of my phone the red line will go away but not permanently. On the left side if I put pressure on the top of my phone it doubles or triples the green line. So right now I have one green line.
Update (09/01/2018)
I have the green line on the left side of the screen also. I also had the red line on the right side of the screen. For the red line I put pressure with my thumb on the top of the phone and it goes away only temporarily. For the green line I put my phone in the freezer for 3 or 4 minutes and cold it down and the green line disappeared. But I don't know how long it will last yet.
Оценка 0
1 Комментарий:
I tried the *#0*# and the line disappeared but it came back. Now I have a triple green lined just left of center. I have a s9
из
If your phone is always on let it cool down. If you don't want to turn it off put it in the refrigerator for a couple of minutes.
Оценка 0
2 Комментариев:
Today my phone was switched off then in the afternoon when there was light then I plug the phone as i plug it ..... It was just showing green vertical line by the left edge ........ So pls what can i do to it because the line is so annoying on the screen ????????????????????????????????
из
I have a Samsung S9. Unfortunately I dropped it a few times and now it has a green vertical line down the center. It only appears when I press the home key to open or when I swipe. What is this and can I fix it?
из
Добавьте свой ответ
Alex akerez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 43
За всё время: 87,350
