A tablet released in September of 2015 by Amazon featuring a 7 inch multi-touch screen display. Model Number: SV98LN
50вопросов Показать все
Black Tape Torn on Digitizer - Amazon Fire 7" 2015 Edition
Attempting to replace the motherboard on an Amazon Fire 7" 2015 model. I did not remove the digitizer before removing the motherboard (as instructions say I should do). I tore the black tape in order to release the motherboard. Am I now going to have to replace the digitizer? Or is everything ok,
You can see the digitizer is still attached to the motherboard. You can also see the black tape that was torn holding it.
Thank you!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
@terdallaujar not sure which black tape you tore. Post some images of your damage with your question so we can see what you see. Use this guide Adding images to an existing question for that. For as long as you did not tear the ribbon cable you should be ok, but we need to see the damage to make that determination.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thank you...I should have done this to start with!
из
Добавьте свой ответ
Kensey будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 81
