Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
115вопросов Показать все
My computer will not read the airport card, what should I do?
I just recently purchased an airport card for my Ibook G3. I put in the card and the computer makes the noise like it is going to start up and then does nothing, the screen remains black. I thought it might be the airport card, but I put the card in an older G3 Ibook and it worked just fine. What is wrong with the computer, do I need to replace the card reader of this Ibook?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Could be a damaged bus or slot on the wireless portion of the logic board. If you have a known good slot you could try replacing it.. other wise you could try to find/use a USB wireless adaptor.
Good Luck,
N.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Part number for the replacement slot (sold by ifixit) is
[связанный продукт отсутствует или отключен: IF150-038-1]
Good luck. Ralph
из
Добавьте свой ответ
Levi будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 671
