The Seagate FreeAgent Go is a portable external drive by Seagate. It was released in May 2010.
My external drive is creating clicking sounds PLS HELP
I’ve had my external drive for a fair long time and this is the first time I’m experiencing this. It was working just fine until I woke up today. I inserted it to the TV (pensonic) last night and watched a movie, It worked well. Then when I woke up I tried inserting it again and the data cannot be accessed although the Usb itself is recognized. I tried inserting it to my laptop and the same happened then I heard clicking sounds coming from it. It is not showing on the devices part of my laptop but I can eject it. And also the light in my external drive is not on.
I don’t know what to do pls help.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
That clicking noise is the search head going back and forth trying to read the disk. It usually indicated a drive that has become unreadable. Sometimes this can happen when the disk is still spinning and the drive is moved.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
What should I do now??? I’ve let it rest for 24hrs but it’s still in the same condition.
из
Hi @kellyanderson ,
If there is important data on it that you need and if the data hasn't been backed up elsewhere you 'll have to find a data retrieval service and see if they can get it off the drive for you.
Be aware this is usually a very expensive process.
из
Добавьте свой ответ
Kelly anderson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 1,556
