Выпущен компанией Samsung в марте 2016 года. Модель SM-G930, Версии: G930F (Глобальная); G930FD (Глобальная; Юго-Восточная Азия); G930W8 (Канада).
Finding IMEI with FRP lock
hey guys.
Im looking to get the IMEI off of a board i got delivered. but its FRP locked. there are no identifiers on the board itself, and the dial code *#06# doesnt work because emergency caller wont allow it.
Am i missing something as to where that should be recorded? i know iphones have the "i" at the bottom corner, but samsung doesnt appear to have it.
Это хороший вопрос?
Счет 10
1 Комментарий
this is lwky a good question, I have the same problem, my best friend gave me her old Samsung Galaxy s7, and she kinda just gave me the password and got tfo so I looked up a ton of shi and the FRP lock is genuinely killing my soul right nowwwww.
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Does Download mode or Recovery mode show the IMEI?
Download Mode may show through adb?
Был ли этот ответ полезен?
Счет 3
7 Комментариев:
neither of them show the imei. Im currently installing ADB to run through the last suggestion. while im doing that, do you have the command i would use to pull the IMEI through adb?
из
adb shell dumpsys iphonesubinfo
из
i get No device/Emulator found When i try to connect. i Have Google USB drivers installed in my SDK manager.
из
Removed comment.
из
Показать ещё 2 комментариев
press volume up, power and home buttons all at same time. While holding down all 3 buttons the screen will start to flash and immediately let up on buttons and hit volume down and the IMEI, SKU and SN will appear on the screen.
Счет 1
1 Комментарий:
Should the phone be off or on ?
из
if the battery cover is original it will have the imei at the bottom, hard to see i suggest some kind of led light to shine against it
Счет 0
Добавьте свой ответ
Scott буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 37
За все время: 12,955
