Finding IMEI with FRP lock
hey guys.
Im looking to get the IMEI off of a board i got delivered. but its FRP locked. there are no identifiers on the board itself, and the dial code *#06# doesnt work because emergency caller wont allow it.
Am i missing something as to where that should be recorded? i know iphones have the "i" at the bottom corner, but samsung doesnt appear to have it.
Это хороший вопрос?
Оценка 7
Добавить комментарий
Ответов (3)
Наиболее полезный ответ
Does Download mode or Recovery mode show the IMEI?
Download Mode may show through adb?
Был ли этот ответ полезен?
Оценка 2
7 Комментариев:
neither of them show the imei. Im currently installing ADB to run through the last suggestion. while im doing that, do you have the command i would use to pull the IMEI through adb?
из
adb shell dumpsys iphonesubinfo
из
i get No device/Emulator found When i try to connect. i Have Google USB drivers installed in my SDK manager.
из
Removed comment.
из
Показать 2 больше комментариев
press volume up, power and home buttons all at same time. While holding down all 3 buttons the screen will start to flash and immediately let up on buttons and hit volume down and the IMEI, SKU and SN will appear on the screen.
Оценка 1
1 Комментарий:
Should the phone be off or on ?
из
if the battery cover is original it will have the imei at the bottom, hard to see i suggest some kind of led light to shine against it
Оценка 0
Добавьте свой ответ
Scott будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 3
За последние 7 дней: 20
За последние 30 дней: 69
За всё время: 11,852
