Компания Apple представила iPhone 5c 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 8, 16 или 32 ГБ памяти; в цветах: Белый, Розовый, Жёлтый, Синий и Зелёный.
1233вопросов Показать все
Im so scared! Helppp
Basically I was stupid enough to take my case off my phone and got my laptop charger. I heard a thud and of course assumed it was my charger. I went back into my room and later went BACK into the other room to get my drink, I looked down and saw my pink phone. I took it into my room and looked at it. The camera was working fine. But from the side I could see light coming through. At first I thought it was no big deal. But now I am actually REALLY freaking out. Im not the OLDEST so its not like I could take it anywhere and im too scared to do the popping into place thing. Because its not like im getting another phone anytime soon. And I need some type of advice. Could anybody help me in any way? My phone is used and it has a crack at the top right corner. The real place its popped out is near the right in the middle side. And the crack makes it look worse from the side. Im SO scared. And sorry this is so long but I need to be honest so I can find an answer. If you help. I owe you one. Thanks. Also. My grandma kinda doesnt know.... *sigh* ~Cassidy <3
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
if the light is shining threw then you need to replace the screen because the screen popped off of the back-light or the LDC shield on the back of the screen broke or came off, either way I would recommend replacing the screen battery and every thing on the display assembly
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
@myphoneisdead since this happened while it was charging it may be a bad battery. If the battery swells it will pop up the screen. post some pictures of what you have with your question so we can see what you see. Use this guide Adding images to an existing question for that.
Eventually you will have to talk to somebody a bit older than you so that you can get your phone repaired. It does not pay to keep secrets like this.
Оценка 3
1 Комментарий:
Top right popping out is a pretty common thing, looks like the screen also needs to be replaced.
из
Добавьте свой ответ
Cassidy Plain будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 104
