Repair information for the Canon PIXMA iP4700 color inkjet photo printer. Released in 2010. Model number: iP4700.
10вопросов Показать все
My printer is having problems Printing.
My ip4700 is printing very faint lines or not at all. This is mostly the black print but the colors are having similar issues.
I did a nozzle check and it was perfect. Everything printed fine. The instructions say not to do a cleaning if the nozzle check is okay.
Any ideas? Thanks.
Это хороший вопрос?
Оценка 0
1 Комментарий:
Hi @dreemsnake ,
What happens if you copy or scan a document using the printer's control panel, does it print OK?
If it does and you are only having problems when printing from a computer, what OS is installed in the computer and how is it connected to the printer, wireless or cable?
из
Добавить комментарий
1 ответ
I would suggest running a cleaning a couple times, and if that doesn't resolve the issue, try replacing the ink cartridges.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
lori будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 557
