Выпущенный 16 сентября 2016 года смартфон нарекли iPhone 7 Plus. Вышло несколько моделей нового устройства: A1661, A1784, и A1785, а также можно было выбрать между версиями на 32, 128 и 256 Гб встроенного накопителя. На выбор можно было приобрести золотой, розовое золото, серебристый, Jet Black и (PRODUCT) Red оттенки корпусов.
No SIM card problem
I bought an iPhone 7 Plus with cracked screen when I put my SIM card at fist it works but 1 minute after the phone says no card sim I tried multiple times but the same problem appears
Это хороший вопрос?
Счет 3
1 Комментарий
I have No Sim problem too..how to fix this?
из
Добавить комментарий
3 Ответов
Выбранное решение
Plausible cause.
-Carrier Locked
-Damaged Sim Reader, really difficult especially with Phones.
-Carrier Settings need to be updated.
*Leave sim in unit, connect to wifi, go to Settings > General> About. This should trigger a carrier update, or simply updating the phone.
-Check Settings > General > Scroll down to Profiles
*Should be in the same area as VPN, and see if a profile from the previous user is interrupting the service (This is primarily dependent on your region/carrier service).
Был ли этот ответ полезен?
Счет 1
I work at an electronics repair store, most of the time the solution is either a new sim card, or reset network settings (you'll have to reenter wifi passwords, but your phone will probably work, worth it).
Счет 0
2 Комментариев:
Juan's first suggestion is very likely, a straight talk or other prepaid carrier locked phone will appear as though it is receiving a signal and it will then fade away. look up the model number on a site like everymac.com for its specs. you will want the model listed under the Settings > General> About area, the model description on the back of the phone is generic
из
i have one iPhone 7 no sim card problem phone looking mother board issue plz help me any friends
из
How can i undo the carrier problem wen ever i put in the line it says invalid sim, ie tht the carrier is not meant for tht sim, what can I do about this
I have an iphone 7
Счет 0
Добавьте свой ответ
Khalid el makhfi буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 18
За всё время: 13,045
