The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Red lines with booting
Dear people,
When i was charging my iPad Air 1 this screen came up.
It totaly freezed up and with the powerbutton and homebutton pressed in it finally turned off.
I've been trying to charge the ipad for 1 day on the charger, didnt work.
Then i removed the screen and disconnect the battery, didnt work.
Does anyone have an idea how to fix this?
Thanks!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
I haven't seen this screen pattern before so I can't offer up a "solution". Did anything happen to the iPad in the days or week prior to this issue? Perhaps it was dropped, damaged, contacted water or was repaired.
At any rate, this device has to be opened up and tested. Perhaps it's the LCD but I suspect a logic board issue. A repair shop that does micro-soldering repairs should be able to troubleshoot this.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Minho! Thanks for your reply!
Nothing happend to the iPad it was just charging.
Do you know which IC or is it the charging electronics?
из
Like I said, it could be multiple things and I haven't seen this pattern before. It could be a damaged LCD, LCD drive circuit or a flex/connector issue.
из
Добавьте свой ответ
Luuk Toonstra буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 525
