Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
Viking Pro Battery Replacement
Can battery be replaced in the Viking Pro RCT6303W87DK?
If possible, Owner or Repair Shop ? ? Soldering Required?
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Выбранное решение
Tom Dibala it is not soldered but uses a connector. Use this video even so it is a slightly different model to open your tablet.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Thanks for link to video(s) - looks fairly simple - - - now need find source for replacement battery!
из
Discovered that problem was with power adapter inside wire apparently was broken from couple years of "flexing" at plugin end. Ordered new adapter (with longer wire) and, although battery does not last long as when new, tablet working OK. Grateful for battery replacement info though - that is probably an upcoming project.
из
Добавьте свой ответ
Tom Dibala буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 4,832
