Stylus C88 Printing Evenly Spaced Thin Black Horizontal Lines
From the time I purchased my Epson Stylus C88 it has printed black evenly spaced horizontal lines through my documents. I have done multiple cleanings, alignments, new cartridges, reinstalled the driver, tried different settings, reset the printer, etc. When I called Epson they said it probably had to do with the fact that I used generic cartridges. Does anyone know how I can stop this. Maybe a way to turn off the monitoring ink. I have seen videos but I do not have the option under maintenance to disable. Maybe someone has made a driver to override the Epson driver? I need to print my resume.
Это хороший вопрос?
13 Комментариев
Hi @maganedinger ,
Does it do this when you copy or scan a document using the printer's control panel?
If not what OS is installed in the computer that the printer is connected to?
Does it do this when only printing from your "document" program (MS Office, Open Office , Libre Office etc) or from any program?
из jayeff
Hello. It doesn't have a scan or copy option. It prints on anything I print no matter if from web, email or a software program. It also prints the lines on the test printed page and alignment. If I have it set to text economy print it prints fewer farther spaced lines and if I print on the best photo setting it prints a lot more lines a lot closer spaced together.
из Magan S Edinger
Hi,
What OS is installed in the computer that the printer is connected to, you didn't say?
из jayeff
Sorry. It was Windows 8 now 10.
из Magan S Edinger
[image|1451440]
I got the same problem on a Epson Stylus Photo 1400 with win 10. Prints parallel lines like in the photo attached either from the Pc or Camera connected. Pls Help ?
из Alexandru Apavaloaie
Показать 8 больше комментариев
