A simple point-and-shoot digital camera with LCD by Canon.
11вопросов Показать все
Lid to battery compartment broken
I love my Canon Powershot A560, especially as it has a viewfinder, as when sunny the screen is impossible to see.
However, the hinged cap that conceals the battery compartment has broken.
Can it be repaired?
Regards
Christine Trufitt
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
@ctrufitty yes you can. Follow the first 6 steps of this guide Removing Canon PowerShot A550 Front and Back Covers since those are pretty identical to your camera.
CAUTION
After the FRONT COVER UNIT is removed, be sure to discharge the main capacitor installed in the
FINDER/FLASH UNIT with use of a discharging resistor. (Discharging resistor: 1 kΩ, approx. 5W)
Never touch the terminal section of the capacitor.
These instructions are from a slightly different model but are typical of Canon's A-model battery cover assembly.
Since there are not good guides on ifixit for this repair yet, you could create some while you do your repair. That would be really helpful for the next person. Use this guide https://www.ifixit.com/Guide/new for that.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Christine Trufitt будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 661
