Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Вопросов 20 Показать все
New home button installed but not working
I had a customer come to me with an iPad Mini 3 with a cracked digitizer and snapped LCD. The home button flex cable was also snagged in the damage and needed to be replaced.
I reused the spacer, gasket and bracket when installing the new home button. However, after installing the LCD and digitizer, the home button isn't responding. I've taken it back apart and reseated the home button flex cable but haven't had a chance to test it yet.
Is there a contact on the home button bracket that needs to be lined up with the home button on order for it to work?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Hello!
If it does not work, it is likely that the flex is damaged. The fingerprint will never work, but the home function should do it.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Bill Shannon будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 89
