sorry to post this as an answer but it's to long for a comment
These directions are taken from Apple.com.
Putting iPod into Disk Mode
http://docs.info.apple.com/article.html?...
"1. Before manually placing the iPod into Disk Mode you should verify
that it has a charge, if not you need to either charge iPod before
continuing or connect it to power. You can either connect it to a
high-powered USB port, or plug the iPod Power Adapter into an
electrical outlet and connect iPod to the power adapter.
2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
3. Press and hold the Menu and Select buttons for at least 6 seconds
until the Apple logo appears.
4. When the Apple logo appears, release the Menu and Select buttons
and immediately press and hold the Select and the Play/Pause buttons
until the Disk Mode screen appears.
5. '''Disconnect iPod from the power adapter and connect it to your
computer; the screen on the iPod will change and say "Do not
disconnect"'''
If you are having difficulty putting an iPod model with a Click Wheel
into Disk Mode, set the iPod on a flat surface. Make sure that the
finger pressing the Select button is not touching the Click Wheel.
Also make sure that you are pressing the Play/Pause button toward the
outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk
Mode, use one finger from one hand to press the Select button, and one
finger from the other hand to press the Play/Pause button."
This of course can also be used in reverse to switch from Hard Drive
mode back to iPod mode.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
5
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
13 Комментариев
Sticky, have you tried to reset it? also, what shape is your battery in? Does your ipod react different when it is plugged into a wall adapter? Have you checked your cable as well as the dock connector on the ipod. Make sure there is no debris or corrosion in it. It does sound like you are having issues with your HDD. and there is no way you are goinbg to send it to Apple. If you can not repair it wherever you are, do feel free to notify my and you can send the iPod to me and I will fix it since I do have all the spare parts here, or I can send you the parts if you want to fix it yourself. The least I can do for any military member.
из oldturkey03
OT...Thanks much for the response, sir. Affirm, it resets and I can put it into disk mode and all that, but none of this seems to help. Interestingly, at least to me,
из Sticky
Whoops...accidentally hit send there...anyway, interestingly, at least to me, it shows up as a replaceable disk drive in Computer when it's not in Disk Mode, but not when it IS in Disk Mode. It always shows up under disk drives in device manager as an Apple USB device. But it never shows in Itunes.
I have no reason to believe the battery is in bad shape and it doesn't seem to behave any different when plugged into a wall adapter. I will take another look at the dock connector, but I don't think it's damaged, at least outwardly. Thanks again for your time,
Sticky
из Sticky
Have you had a chance to run the diagnostics and see if it checks your HDD okay?
из oldturkey03
Yes sir, if you mean the diagnostics you run through Itunes. It never finds the Ipod when it gets to that part. I'm starting to get the impression there is something indeed wrong with the HDD.
из Sticky
Показать 8 больше комментариев
