A gaming laptop released in Asus's G74 Republic of Gamers series in 2011.
7вопросов Показать все
My srceen has a vertical
my screen has a vertical white line its gets bigger and smaller and some time its turns red or blue or both even clear in the middle i know its the lcd or video cable i tried to reconnet it from the lcd but it didn't work i need to know if i need to buy the lcd or video cable and opening and closing doesn't work
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
aluzy that sounds like a TAB error on your LCD (Bonding between the ribbon cables and the panel has failed.) A new LCD will fix this. Just to make sure, post an image of what your display shows with your question. That way we can see what you see. Use this guide Adding images to an existing question for that
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
aluzy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 72
