Power jack not working all of the time
How do I replace the DC power jack and cable? Is there a special part number for an E1-572-6676? Where can I get a replacement cable?
Это хороший вопрос?
Это хороший вопрос?
Hi @canblue ,
The power jack charging port is a plug in module so it should be easy to replace it.
Here is a link to the ifixit ACER Aspire E1-572-6870 Fan Replacement guide. It is useful as it shows how to get access to the motherboard in the laptop, so that the charging port can be replaced.
Here is a video which may also be of some help. Not the same model number but close enough to be of some use.
Here is a link to just one supplier. It is not a recommendation to use them it is shown to give an idea of the cost of the part. There are others online that may suit you better. Just search for Acer Aspire E1-572-6676 Dc-In jack part to get results. The part is the same for all Acer Aspire E1-572, E1-572G and E1-572P Series laptops
Hopefully this is of some help
Был ли этот ответ полезен?
While reviewing the answer submitted by JAYEFF and looking for replacement part, I spent a little more time investigating my problem. I thought that the connector had come lose on the board. I looked a little closer at the connector and noticed that the negative connectors on the DC power connector wer only 2 spring like clips instead of a full collar. Since the replacement part arrived I decided to attempt an in-place fix. I did spend a little time looking at the replacement part before trying this. I found a round piece of steel, it was a "large" regular sewing needle. A paperclip will not work. A needle for sewing leather might work better since it would be stronger. I unplugged the computer and removed the battery for safety reasons -- did not want to short anything. I inserted the needle and used it to
pry the clips, inside of the connector, towards the power pin. I did not apply a lot of pressure because I did not to brake the clips or move it out so much that it would short the positive pin when on battery power. I test fitted the DC power plug into the computer and it no longer was wobbly. As I mentioned in the first post, the DC power was intermittent because the connector was not always making the connection so it fluctuated between battery and DC power causing some low battery conditions where the computer shut down.
There is no warranty on the suggested fix. You evaluate my suggested fix and assume all responsibility if you go forward. I suggest that you have a replacement cable available just in case you need to replace the cable. We will probably need to replace the cable eventually. Let me know if the simple fix worked. Any feedback/comments appreciated.
The crappy quality of this connector, and the poor touchpad are the reasons I will never again buy an Acer computer.
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 10,380
1 Комментарий
I bought a supposedly new power jack for this E-1 on Ebay. Did the work only to discover it was as loose as my old one. It must be a used jack some scumbag sold just to get a few bucks. This cheapo computer is known for the jack going sloppy so if you find a replacement, be sure you get an actual new one. You can not tell by looking. if you find one and it is not in factory packaging, don't go to the trouble to install it.
из geodevos
