The LN46A530 has a 46" display, combined with SRS TruSurround XT. The PC input allows this display to double as a 46" computer monitor
71вопросов Показать все
How can the optical sound output be connected to RCA amplifier?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Here's a good vid on how its done and what you'll need: Digital to Analog Audio Converter Optical / Coaxial / USB. There are many suppliers besides this company.
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
Hi,
Here is an image which shows how to connect an optical cable between the TV and the RCA amp, if it has an optical input that is. You didn't give the model number of the amp.
(click on image to enlarge for better viewing).
If you wish to mute the audio from the TV speakers when you have connected the TV to the amp go to Menu > Sound > TV speakerand select Off. If you leave it set to On you will have audio from both the TV speakers and the amp.
Оценка 1
Добавьте свой ответ
David Vives Llor будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 2,341
