Upgrade eMMC storage in this laptop?
Hello,
My girlfriend's mom purchased this ~$200 laptop awhile ago and it has a 32 GB eMMC hard drive in it. I can't seem to find any information online about this laptop, but I was wondering if anyone knew:
a) if this laptop has a sata drive slot, I know that it doesn't have a DVD drive so I can't just stick a sata SSD in that way.
b) If I can change the boot order in the BIOS to boot from the sata SSD. I understand that this is a pretty basic BIOS feature but you never know with these cheapie laptops
I was able to find a lot of information about the HP 14-an013nr however I can find very minimal information about the HP 14-an012nr.
Thanks for the help!
Update (01/27/2018)
This might be stupid as well, but is it possible to have a spanned volume with the eMMC boot drive as well as a USB Flash Drive or an SD card?
Это хороший вопрос?
4 Комментариев
I was given this same laptop and it doesn't even have enough hd space to update Win10. I want to install the sata hd from my old laptop but don't know if it will be compatible. Will it work? What info do you need from me to answer. The sata is a wd
из unicorn315
There was a port inside the laptop that was meant for a dvd drive. I ordered this caddy from amazon: https://www.amazon.com/gp/product/B0177A...
and stripped out the internal circuit board to install a SATA drive. I then cloned the os and everything else over to the new drive and swapped the boot order over to the new drive from the BIOS. I hope this was helpful!
из Chris D
This video was also helpful in the process. https://www.youtube.com/watch?v=ulmmYmbw...
из Chris D
Is there an adapter to allow me to use the removed eMMC card as a USb drive?
из Keith Goldstein
