GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152вопросов Показать все
ipad wont turn on and wont charge
I tried charging it today on the ipad charger an left in on at 34% for a couple hours.
When i went back to check on it, it was dead like it needed a charge.
I tried holding the top and home keys for 30 seconds.
I also let it charge for way more then an hour and checked it periodically throughout
the day. I also tried connecting to the computer but he mac book pro doesn't recognize it. First time this is happened, I have had this ipad 2 for a year.
I really need this fixed I am leaving on a trip in a couple days.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Try another cable and ensure you are using at least a 2A charger.
Are you able to see low battery logo at least on the screen? If not check charging port it could be physically damaged.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Yes I am able to see low battery logo
из
Добавьте свой ответ
Orion Angel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 80
