The Envizen V100M Tablet, is a tablet PC made by Envizen Digital, a brand under Diamondking Inc. This company makes several tablets, all of which run an Android operating system.
make sure you have update.zip in nand or sd card
when is choose system update it states NOT FOUND PLEASE MAKE SURE YOU HAVE UPDATE.ZIP IN NAND OR SD CARD.
How can I fix this?
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
Выбранное решение
Hi,
If you are trying to update your tablet, I'm not sure if you can anymore.
When you try to update the system from the Settings menu (is this what you are doing?), the message you are receiving, indicates that it is programmed to either automatically download the update from the Envizen website if one is available or that you can manually download the firmware update from the Envizen website, store it on the SD Card and run the update from the card.
The Envizen website appears not to exist anymore. According to the User Manual Envizen VM100, for customer support you should contact service @envizendigital.com. When you lookup the envizendigital.com website it doesn't exist anymore.
Был ли этот ответ полезен?
Счет 4
1 Комментарий:
@jayeff - Well that sucks ;-}
из
Do you have the file called UPDATE.ZIP ? And is it the correct file from Envizen for your tablet? I would contact them to make sure. The OS updater service is looking for the file and for some reason can't locate it. It needs to be on the system on the main flash storage (NAND) or SD Card.
You also need enough space on the NAND for it to expand. You may need to delete or copy off as much stuff as you can (i.e. pictures, games or books). Frankly I would make a full backup externally to be sure I don't loose anything.
Счет 2
Добавьте свой ответ
Janice Dockery буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 4,165
