The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
371вопросов Показать все
How do I plug in black ZIF connectors?
Subject: https://prnt.sc/iae8ex
From this picture, we see that A is a normally ZIF connector. It has a lovely clamp which can be opened to release the cable. Super cool! But the B connectors are different. I find them difficult to reconnect. Especially the first B cable I've pointed at. It's super flexible and kinks when I try to insert it into the housing. The second B cable I looked at has a little notch which I can use to properly insert it back into position ( http://prntscr.com/iaedj9 ) (How it should look like when plugged in. This is in case I've confused you http://prntscr.com/iaebz7 ).
Any help? Any questions? This is the first time doing something like this by myself. Thanks for your time. I would appreciate any type of reply and direction.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
There is a clamp. Should probably update this guide! http://prntscr.com/iaeyej
On the other side of the housing there is a flap. It didn't break when I flipped it. Read my reply to Ben in the comments for more information.
New Nintendo 3DS XL 2015 Game Card Reader Replacement
Был ли этот ответ полезен?
Оценка 0
In the image you linked, the grey clip is missing from that Zif connector, if you were to put the cable inside without that clip which is missing, it wont let the ribbon cable touch the pins as the clip is not pushing the cable in place.
Оценка 0
2 Комментариев:
I was following the guide on this device. All images are from the teardown of this device from this website. And the image with the notches I drew is kinda wrong. It does have it but its a lot less pronounced than the 2nd B cable.
The guide said "Note that these ZIF connectors are held in place by friction and do not have locks -- lifting the flaps on these connectors will break them!".
On the other side of the housing there is a flap. It didn't break when I flipped it. I just booted my system up and it works. The connector is like any other one, it will let go when flipped up, and clamp it down, making contact when flipped down, not "bReAk" them. If anything, this guide is super misleading.
из
You are right, it should say prying the flaps off instead.
из
Добавьте свой ответ
Luke будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 12
За всё время: 888
