How to factory reset the Fire stick without any remote or app?
Why is my Fire Stick disconnected from the internet after I ran a "Share it app"? The remote also stopped working. I can't use the Fire TV Remote App as the Stick has no internet access.
I sideloaded an android app "share it" it on firestick but when I tried to send the data from my phone to fire stick, the screen just froze. I had to restart the TV but by then fire stick had lost the network access. Fire Tv -Stick is dispaying "No network access" message. Earlier it was connected to two modems but now its not detecting either of them. Somehow remote also stopped working. I tried two diffrent physical remotes (with fresh batteries) but now I can't navigate inside it by any means.
I don't know the reason but I guess the ‘share it’ app tried to create a shared hotspot network to allow data transfer but maybe fire stick is not configured for it.
Is there any method to factory reset the device without turning it on ?
Это хороший вопрос?
13 Комментариев
I have this same exact issue. Brand new firestick from the store. Loaded es file explorer and moved 2 apk’s that I’ve placed on 4 other firesticks and using the same method.
After the transfer I didn’t jump back to the firestick immediately, but when I did I noticed it was a black screen with “no network connection” in the lower left corner.
The remote wouldn’t work nor WiFi. After a few power cycles and being quick with keeping the remote buttons pushed I managed to get to factory reset.
That worked until I got signed in to my amazon account and then it lost network connection again and it’s stuck at a point (sign up for prime) spot that the remote will not work after power cycles and is at this point bricked. And all before I could actually install anything :/
из George
@christopher715 Thank you!
@jonschr yes i was looking for something like that only, but a USB mouse worked for me. Thank you!
@stephen Thank you so much, I did get to try your method but it looks very promising. :)
из Yogesh Arora
What is a usb mouse
из Brittney Williams
I had a Firestick 1
Dead no remote.
With a pin lock.
Linked to computer with ADB with usb lead( jocola.com)
With windows but you can download apple or Linux version.
Plugged in hdmi end into the display
It asks to set Firestick to usb debugging.
No mouse or control.
Downloaded CetusPlay app on both an android or iPhone.
Linked android or iphone as hotspot
You are then able to access Firestick system settings
Go network and link network hotspot
Link Wi-fi
With Cetus
You do not have the facility with Cetus.
For the next move
So download Firetv App.
Link firetv app
Go to setting again.
My device/ my fire tv
Reset factory defaults
Then press the reverse and fast forward button at the same time.
Until factory reset comes up.
I think it took 10/ 12 attempts to achieve a factory reset.
Press reset.
You should then have a virgin Firestick as new
Took a bit of working out by trial and error.
This also circumvents pin code lock.
Nothing else worked for myself.
I now have a clean Firestick.
Good Luck
из Frank
Seems long winded.
Just follow each step.
It actually works without have to buy-extra leads or a mouse.
Once you have ADB installed on you computer your half way there.
Using version 3.8.
All free software.
из Frank
Показать 8 больше комментариев
