Repair guides and support for LED, LCD, HD and other Vizio TVs.
931вопросов Показать все
E420i-A0 picture and sound keep going out
E420i-A0 When first turned on everything works fine for a few minutes. Then the screen will go black and the sound stops also. It will then come back on sometimes for a couple of minutes, and then go out again completely. I can then press the power button and the V will appear followed by HDMI-1, DIRECTV, in the upper right corner. Also "1080i" flashes on and off to the right of DIRECTV. No picture or sound appears. If I turn it off and leave it for a couple of hours, I can go through the same routine all over again. My thought is that one or more components on the boards is getting hot and breaking down. Any suggestions? Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@provmobile this sounds like an issue with either the power board or the main board. It could be capacitor failure which would manifest itself with the symptoms you describe. remove the back off your TV and take some good pictures of all of your boards. Post those with your question so we can see what you see. Use this guide Adding images to an existing question for that
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thanks, I will have to have someone take it down for me as I am disabled so pictures can be taken.
из
Sounds silly but have you tried new cables, especially if you have a cat. Cats seem attracted to VGA and HDMI cables.
Оценка 0
1 Комментарий:
No VGA or HDMI attached. Just the cable from the Directv box. Thanks for the response.
из
Добавьте свой ответ
JOHN WHITAKER будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 147
