The Lenovo G50-80 is an entry level personal laptop released by Lenovo in 2009. The laptop has a 15.6 in screen and uses an Intel GPU processor.
16вопросов Показать все
My display is gone black. It works when connected to external monitor.
My laptop displays a black screen when switched on. However, there is a display when connected to an external monitor. Is it a display problem entirely? How much is the charge to replace display? There is no external damage to the display screen though.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Hi @mohua ,
With the laptop on and a display showing on the external monitor, shine a torch at an angle close to the laptop screen to check if you can "see" an image at all.
If you can you have a backlight problem.
This could br caused by a faulty backlight power supply from the motherboard, faulty backlight cable (not sure if it is a separate cable or part of the video cable), a faulty lid switch or a faulty LCD panel.
If you cannot detect any image at all (try in a darkened room, as it may be easier to see), then you may have a faulty video cable, faulty video cable connections at either end (motherboard or screen) or a faulty LCD screen.
Here's a link to the service manual for your laptop which may be of some help.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Mohua будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 1,990
