Solder points for wires to speaker
I have a pair of Beats mixr headphones with the aux cable soldered straight to the speaker (don’t know why). A wire from the wider cable and a wire from the aux cable have deattached and I would like to see a tear down to see where to re-solder the wires onto the speaker. I can’t take out the Monster cable (it’s actually a genuine cable), and one ear works. The other ear has another aux port. When I use another aux cable, the ear that doesn’t work with the other cable works, but not the one that worked last time. So I have to use a headphone splitter and plug in both cables for both ears to work. But that’s a pain. How would I re-solder the deattached wires? An image of the disconnected wires is below.
Это хороший вопрос?
Оценка 0
2 Комментариев
@dudeperson post some images of where you see the wires disconnected etc. with your question. Use this guide Adding images to an existing question for that so that we can see what you see.
из
Alright added a photo.
из
Добавить комментарий
1 ответ
Выбранное решение
@dudeperson use a multimeter and see if you have continuity between point 3 and 4. Measure between 1 and 3 and 2 and 3 and make sure that you do not have continuity. If those points are true you can solder the ground wire to point 3 or just solder it above or with the ground wire (green arrows) coming from the input cable.
Был ли этот ответ полезен?
Оценка 4
4 Комментариев:
I won't be able to try this until about March 17th.
из
@dudeperson that is fine. Absolutely no problem Somebody will be here to help you out:-).
из
I tried it. I edited the photo to what we tried.
из
Looks like I missed the other wire . Try to connect that to #3 if that does not work connect to bottom of #2 with the green wire.
из
Добавьте свой ответ
Jackson Blade будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 15
За всё время: 1,340
